Buongiorno a tutti e grazie sempre per le vostre risposte!!
Ora qualcuno potrebbe interpretarmi questo sembra un alfabeto morse
Aiutoooo
Basically, started with full throttle enters programming mode. one to 6 beeps
after music. Select topic by moving throttle to center (not bottom). Select
setting by moving to full throttle.
topics:
1 beep - cell type, no of cells
-" = nimh auto, ".--" to ".------" no of lipo cells (lowest last).
2 beep -
throttle setting
"..-" auto, "..--" 1.1 to 1.8 ms fixed
"..---" hard acc, "..
----" soft acc
3 beep - brake setting
"...-" soft", "...--" med, "...---" hard
4 beep - direction + cutoff
"....-" norm, "....--" reverse
"....---" soft
cutoff, "....----" hard cutoff
5 beep - timing
".....-" 1 deg, then 7, 15, 30
deg
6 beep - pwm freq
"......-" 8khz, "......--" 16khz
