Vecchio 27 settembre 09, 00:34   #2 (permalink)  Top
Highly Flammable
Sospeso
Data registr.: 09-07-2009
Secondo il manuale, il punto di bilanciamento statico è a circa 115-120 mm dal bordo d'attacco della radice alare:
Balancing the Messerschmitt BF 108 B TAIFUN
Assemble the model completely (fueltank empty), invert it, and support it under both wing roots at a point about 115 mm to 120 mm aft of the wing root leading edge. If the CG position is correct, the model will hang level, with the nose inclined slightly down. If necessary, glue lead ballast to the nose or tail to obtain the correct balance. All the control surfaces must be exactly at centre when the transmitter sticks and trims are in the neutral position; check this before the first flight.
Manuale (en):
http://www.graupner.de/fileadmin/dow...39_9387_gb.pdf
Manuale (de):
http://www.graupner.de/fileadmin/dow...ungen/9387.pdf
BTW, bellino il Graupner Bf 108 Taifun, dove lo vendono in Italia?
Pensavo di acquistarlo per un RCV60-SP (0.60 cu in / 10 cc):
RCV90SP installed in a RC Model ME109 Taifun Aircraft
Voi che ne dite?
Highly Flammable non è collegato   Rispondi citando
