Discussione: Ju87 Stuka by Ziroli
Vecchio 27 agosto 09, 23:50   #20 (permalink)  Top
MarcoGhe
L'avatar di MarcoGhe
Data registr.: 14-11-2007
Residenza: Quà e là
Ho trovato questa su un topic di RCScale Builder, mi sa che con questa mi sono parato il cu..o da errori
Sheet
6 pcs 1/16" x 3" x 36" balsa stab. covering
6 pcs 1/16" x 4" x 36" balsa flaps, ail, fin & rudder
15pcs 3/32" x 4" x 36" balsa centre sec. Covering & ribs
14 pcs 3/32" x 4" x 48" balsa wing covering & ribs
12 pcs 1/8" x 4" x 48" balsa fuselage covering & stringers
Strip
30 pcs 1/8" x 1/4" x 48" balsa Fuselage stringers
1 pcs 3/16" x 1/4" x 36" balsa Fin spar
10 pcs 1/4" sq x 48" balsa Rib shim, L.E., Stab, Ail, Flap
3 pcs " 1/4 x 1/2" x 48" balsa Fuselage crutch
6 pcs 1/4" x 1/2" x 48" Spruce or hard balsa Wing spars
2 pcs 1/8" x 1/2" x 36" balsa Fuselage crutch
2 pcs 1/8" x 1 1/2 " x 48" balsa Wing leading edge
2 pcs 1/4" x 5/8" x 48" balsa Stab, T.E., Elev, L.E.
1 pcs 1/4" x 1 1/4 " x 36" balsa Fin post, rudder L.E.
2 pcs 1/4" x 1 1/2 " x 48" balsa Wing L.E.
2 pcs 3/8" sq x 48" balsa Ail & Flap L.E.
Plywood
5 pcs 1/8" x 12" x 24" Light ply Formers & Ribs
1 pcs 1/8" x 12" x 24" Birch/Aircraft ply Ribs, Joiners
1 pcs 1/4" x 6" x 12" Birch/Aircraft ply Mount Plates, etc
Other
1 pcs 3/4" x 1 1/4" x 12" balsa Wing tips
4 pcs 1/2" x 3/4" x 9" hardwood (1/4" x " centre grove) Landing gear mounts
2 pcs 3/4" x 1" x 4" hardwood Wing mount blocks
1 pcs 1/2" dia x 6" dowel Wing mount
2 pcs 1/4" dia x 36" music wire Landing gear OR use Oleo's
This is the complete material list if your using wire legs. I do recommend that if you can afford the Oleo's go that route. There are many advantages and will give you longevity and save you repairing the wheel pants many times.
Also plan early what engine your going to use, as this will have an influence on the exhaust (muffler) needed. The cowl is narrow and a Zenoah G62cc fits nicely but requires the long prop extention. The "D" of "G" version cowl would be very difficult to change to and get the engine in the right place, as it's longer and just as narow. The main problem is the chin being below and far away from the prop
Have a great build and enjoy.
Ora mi resta che verificarla sul disegno e procedere.
MarcoGhe
Mustang P51D Marutaka - in costruzione, Texan AT6 Balsa Usa - in riparazione
Rafale HET - Easy Star per riprese aeree - Piper Cub 10e Hyperion - Trex 450 Se V2 - Walkera 60 full upgrade
MarcoGhe non è collegato   Rispondi citando
