Vecchio 04 agosto 09, 16:13   #8 (permalink)  Top
charly2
L'avatar di charly2
Data registr.: 31-07-2009
Residenza: distese pianeggianti o in montagna
Team Orion USA Avionics Advantage Flight Charger
ti può interessare questo modello? Team Orion USA Avionics Advantage Flight Charger
Io lo sto vendendo, ti allego le caratteristiche se vuoi:
Key Features
Capable of charging and Discharging:
NiCD/Ni-MH 1-14 cells
Li-Io or Li-Po 1-5 cells
lead acid (Pb) batteries 1-6 [2V per cell]
Adjustable charge current (0.1A-5.0A)
Adjustable discharge current (0.1A-1.0A)
Cycling (Charge to Discharge / Discharge to Charge)
Overview
Team Orion Avionics Advanced Flight Charger is the must have option for those serious about electric flight. With a ton of features packed into it’s compact size, the Advantage Advanced Flght Charger provides all the features of a large size charger, without the size, weight and expense.
Specs
Input:11-15V DC
# Cells:NiCD/Ni-MH 1-14 cells, Li-Po cells 1-5 (3.6 or 3.7V), Lead Acid cells 1-6 (2V per cell)
Charge Rate:0.1A - 5A
Trickle Charge Rate:0 - 250mA
Input Connector:Alligator Clips
Output Connector:Banana Plugs
Battery Type:Ni-Cd, Ni-Mh, Li-Po, Li-Io, Lead Acid
LCD:2 line, 16 character LCD backlit
Discharge:Yes, Discharge curent: 0.1A - 1A
Se sei interessato contattami charly2@eaglephoto.it
... Avere l'aria come primordiale elemento...
ed addensarla al punto esatto da renderla un bene cavalcabile...
ed io sono il sognato Pilota...
charly2 non è collegato   Rispondi citando
