Ecco Massi,
# Castle Link Data File
# Created: lunedì 3 agosto 2009
# Do Not Edit This File By Hand
Brake Strength: 0
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Current Limiting: Insensitive
Cutoff Voltage: Auto Li-Po (*)
Cutoff Type: Soft Cutoff
Motor Start Power: 39
Motor Timing: 5
Direction: Forward (*)
PWM Rate: 12 Khz (*)
Hex55: 85
Vehicle Type: Helicopter
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 3
Initial Spool-Up Rate: 5
Head Speed Change Rate: 5
Auto Rotate Enabled: False
Governor Mode Type: Fixed
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 6
Vehicle Setup - Battery Voltage: 22,2000
Vehicle Setup - Gear Ratio: 12,461
Vehicle Setup - Motor Kv: 1600
Vehicle Setup - Motor Number of Poles: 6
Desired Head Speed 1: 2343
Desired Head Speed 2: 2552
Desired Head Speed 3: 2690
Ho una mx12 e quindi posso provare solo normal e idle1....
Che dici di questi valori?
Grazie anticipatamente
