ecco cosa ho trovato girando qua e la:
Dati Prodotto
DLE-30 ENGINE AVAILABLE SOON!
Performance
Power: 3.7hp at 8500rpm
Idle: 1600rpm
Static Thrust: 8.5kg at 100 Meters 7.5kg at 1800 meterswww.dlengines.com
Dimensions
Displacement: 30.5cc
Bore and Stroke: 36mm x 30mm
Compression Ratio: 7.6:1
Weight: Engine - 910grams Muffler- 60grams Ignition - 120gram
DL Engines and Hobby Australia Requirements
Fuel: 2C Regular Gasoline mixed 30:1 - 45:1 (Mineral based at 30-32:1 for breakin, 45:1 quality synthetic thereafter)
Propellor: 18x8 ; 18x10 ; 19x8 ; 20x8
Ignition Battery: 4.8 - 6v (max) >= 1200mah
Replacement Spark Plug: NGK CM6 or quivalent
Plug Gap: 0.018" to 0.020:
Installation Torque: 7 to 8 ft-lbs
Sii il primo a recensire questo prodotto!
