Vecchio 26 giugno 09, 19:34   #29 (permalink)  Top
piratasegreto
L'avatar di piratasegreto
Data registr.: 30-09-2006
Residenza: Foggia
Che ne dite di questo kit????
The GWS EDF64 + CP450-5000-30EDF Power Unit Can Replace For Those 64mm Stock Fan System Of Most RTF Version Foam Jet In The Market, To Provide The Foam Jet With Super High Power & Speed In 3S (11.1v) Setting !
GWS EDF64 Specification:
Duct Case Size: 63.9mm dia. x 41.5mm L
Propeller: 2540x6
Weight: 28g (without Motor)
Motor Shaft: 3.0mm
CP450-5000-30EDF Motor Features:
- New Version & Design EDF Motor
- Super High Power & Effiency
- Suitable For 55mm - 65mm Ducted Fan
Description:
- Kv: 5,000 RPM/V
- Cont Current: 50A Max
- Motor Shaft Diameter: 3.0 mm
- Weight: 85 g
Test Data:
GWS EDF64 (6 Blade) + CP450-5000-30EDF Motor + 11.1V Static Thrust: 740g 42A
piratasegreto non รจ collegato   Rispondi citando
