Vecchio 23 giugno 09, 21:22   #327 (permalink)  Top
geco73
L'avatar di geco73
Data registr.: 11-06-2008
Residenza: otranto
Originalmente inviato da inquisitore Visualizza messaggio
Non è il bip il problema.... MA IL MOTORE CHE GIRA!!!
Cmqe ho scritto alla castle, vediamo di fare qualche test app posso
----- Original Message -----
Sent: Wednesday, June 17, 2009 11:22 PM
Subject: Re: Strange behaviour... very short power on!
> All settings look good. Only other thing to try is current limiting
> disabled instead of insensitive. Batteries are fully charged? Does the
> motor spool up to full speed if not meshed with main gear? Let me know.
> Joe Ford
> Product Specialist
> Castle Creations
> >> Hi Joe,
>> thanks for your quick reply.
>> What do you mean, exactly?
>> Here the setting of my ESC (Skorpion motor 1400kv, pinion 15, lipo 6s,
>> external bec):
>> Brake Strength: 50
>> Brake Delay: .6 sec (Delayed) (*)
>> Brake Ramp: Immediate (*)
>> Current Limiting: Insensitive
>> Cutoff Voltage: Auto Li-Po (*)
>> Cutoff Type: Soft Cutoff
>> Motor Start Power: 59
>> Motor Timing: 5
>> Direction: Forward (*)
>> PWM Rate: 12 Khz (*)
>> Hex55: 85
>> Vehicle Type: Helicopter
>> Throttle Type: Governor Mode
>> Throttle Response: 5
>> Governor Gain: 3
>> Initial Spool-Up Rate: 5
>> Head Speed Change Rate: 2
>> Auto Rotate Enabled: True
>> Governor Mode Type: Fixed
penso che sia normale io ho 3 esc tutti di marca diversa e il motore si e sempre mosso al attacco del esc
geco73 non è collegato   Rispondi citando
