Vecchio 18 giugno 09, 16:23   #316 (permalink)  Top
inquisitore
L'avatar di inquisitore
Data registr.: 19-08-2008
Residenza: Verona e dintorni
Originalmente inviato da terminator7 Visualizza messaggio
Ciao,
il beep e' normale.
Lo fa ogni 20 secondi.
Semplicemente e' un avviso che il motore e' armato,e' una sicurezza introdotta con la versione 2.0
Come dai un po' di gas e fai partire il motore il beep non c'e' piu'
Marco
Non è il bip il problema.... MA IL MOTORE CHE GIRA!!!
Cmqe ho scritto alla castle, vediamo di fare qualche test app posso
----- Original Message -----
Sent: Wednesday, June 17, 2009 11:22 PM
Subject: Re: Strange behaviour... very short power on!
> All settings look good. Only other thing to try is current limiting
> disabled instead of insensitive. Batteries are fully charged? Does the
> motor spool up to full speed if not meshed with main gear? Let me know.
> Joe Ford
> Product Specialist
> Castle Creations
> >> Hi Joe,
>> thanks for your quick reply.
>> What do you mean, exactly?
>> Here the setting of my ESC (Skorpion motor 1400kv, pinion 15, lipo 6s,
>> external bec):
>> Brake Strength: 50
>> Brake Delay: .6 sec (Delayed) (*)
>> Brake Ramp: Immediate (*)
>> Current Limiting: Insensitive
>> Cutoff Voltage: Auto Li-Po (*)
>> Cutoff Type: Soft Cutoff
>> Motor Start Power: 59
>> Motor Timing: 5
>> Direction: Forward (*)
>> PWM Rate: 12 Khz (*)
>> Hex55: 85
>> Vehicle Type: Helicopter
>> Throttle Type: Governor Mode
>> Throttle Response: 5
>> Governor Gain: 3
>> Initial Spool-Up Rate: 5
>> Head Speed Change Rate: 2
>> Auto Rotate Enabled: True
>> Governor Mode Type: Fixed
Tarot 500 alias Trex 500 foto | Tarot 450 alias Trex 450SeV2 | MD500Hughes Tarot450SeV2 *Hitec Optic6 + Corona 2.4* + EasyStar II
inquisitore non è collegato   Rispondi citando
