veniamo al dunque :
Trasmittente 4 CH+ rx micro 6 CH 40mhz art-tech E-fly 100c
il primo :
RC Smart 2810 KV Outrunner Brushless Motor and 30A Speed Controller ESC
for RC Model Airplane
Specifications
Rotational Speed 2810 RPM/V
Continuous Current 20A
Max. Current 25A
Input Voltage 6 - 22V
Max. Efficiency 98%
No Load Current 0.7A
Internal Resistance 56mΩ
Motor Dimensions (Diameter x Length) 31mm x 26.4mm
Shaft Dimensions (Diameter x Length) 2.82mm x 30.5mm
Input Battery Types NiCd/ Nimh/ Li-po Battery
Recommend Model Airplane
Specifications
Dimensions 51mm x 24mm x 8.3mm
Sustaining Input Voltage 6 - 18V
BEC Output Current 5V/3A
Continuous Output Current 30A
Max. Output Current 40A/12s
Internal Resistance 0.0021mΩ
Cable Type 16 AWG (Battery & Motor)
Cable Length 72mm (Battery)
72mm (Motor)
190mm (Receiver)
Recommend Model Helicopter / Airplane
il secondo:
http://imgs.inkfrog.com/pix/rctimer/2212-6.jpg
RC Smart 40A Brushless Motor Speed Controller ESC
Dimensions 47.5mm x 36.1mm x 8.9mm
Sustaining Input Voltage 6 - 30V
Continuous Output Current 40A
Max. Output Current 50A/12s
Internal Resistance 0.0018mΩ
Cable Length 75mm (Battery)
80mm (Motor)
190mm (Receiver)
n.5 servocomandi 9g
Batteria lipo 3 celle 11,1 volt 1600 mAh quanti C di scarica?? non so cosa dire come si vede?
Caricabatterie Bilanciato lipo art-tech:
Input voltage: DC 10V~15V
Output voltage: DC 7.4V&11.1V(to 2 or 3 cell Li-Po battery)
Charging current: 0.3A~1.0A (can be continuously adjusted)
Dimension: 72 ×49 ×22mm/2.8×2.0×0.9in
