Vecchio 18 maggio 09, 23:43   #2 (permalink)  Top
illogicist
Data registr.: 04-11-2008
Residenza: AOSTA
ecco le specifiche tecniche:
WALKERA 180L BRUSHLESS MOTOR
* Dimension: ?? 20X40mm
* Speed constant(KV): 3200RPM/V
* Working voltage: 6-18V
* Shaft extension: 13.5mm
* Shaft diameter: ??2.3mm
* Weight: 65g
Walkera Speed Controller 30A ESC
Sustaining voltage: Approx. 6-17V
BEC current: Approx. 3.0A
Continuous output current: Approx. 30A
Instant max current: Approx. 50A
Inside impedance: Approx. 0.0044 Ω
Reversion: yes
Low voltage, cut electricity protection: yes
weight: 32.4g(approximately)
Pacco batterie:
Flightpower Extreme 2200 mAh - 11.1 V - 3 celle
Elica e riduttore: originali Easy Glider Electric
illogicist non รจ collegato   Rispondi citando
