anche se come modello non mi dice nulla, gironzolando per le rete l'ho trovato a 11 (leggete bene undici) è solo depron tagliato, senza nessun accessorio, ripoto quello che c'è scruitto sul sito:
Description:The flying hydraulic boat. To country, to water and in air.
- slips, swims, flies -
Model low-cut out of white Depron material, all Depron parts, construction period saving substantial thus. Model weight without RC and drive 63 gram. For the completion still coal reinforcement are needed. Drive brushless Axi 2204/54, 2 Lipo cells 350 mAh. For the control 3Stk Servos B-1054 are similarly needed or.
Note!
The supply of the model takes place without any accessories. In the kit are only the prepunched parts from Depron and a building specification. You find this building specification here also as Download. In this version also some photos of the finished flugbootes are to be seen.
questo è il sito: http://www.der-schweighofer.at/web/p...10&prodID=1063 Ciaooooooooooo p.s. non conosco il sito e non ho mai comprato da loro.
