Ho notato che in rete c'è chi sta facendo molta confusione riguardo lo storing delle batterie lipo, in molti propagano informazioni sbagliate, a danno di coloro che, convinti di seguire la procedura giusta, danneggiano le proprie batterie.
In effetti anch'io all'inizio ho commesso questo errore, sulle vecchie flightpower evo20, in quanto le stesse persone che me le hanno vendute, mi hanno dato dei consigli "sbagliati"
Guardate quì...
Li-Po Batteries Prolonged Storage Guide - Electric RC Helicopter
If the Li-Po battery is brand new and you decide to keep it for a while before putting it to first use, contrary to common sense, it is best not to store the battery in its uncharged state. The best practice is to fully charge it and maintain it at 4.2 V per cell before storing the battery away for a long time. For example, if you bought a 3-Cell Li-Po battery rated at 11.1 V, when fully charged, the battery will hold 12.6 V. This will make it suitable to keep stored away for 3 to 6 months. However, after 6 months, the voltage will start to weaken. When this happens, fully charge it again, whereby giving another 6 months of storage time. While this procedure can be performed over and over, the battery shouldn't be kept without being used for more than 2 years."
Infatti il tipo viene prontamente corretto.....Qualcuno gli fa capire che sta dicendo una bischerata..
I'm sorry, but your advice to store Lipo batteries fully charged is COMPLETELY WRONG!!! All Lipo manufacturers and suppliers advice that you MUST store Lipo batteries at about 50% charge. Storing at 100%/fully charged will cause an increase in the resistance of the battery, meaning that it may not be able to supply the needed current after a long storage or it will heat up more during flight, causing the battery to die much faster.
To estimate 50% charge, measure the voltage of each battery and it should be between 3.80V - 3.90V..
Lipo batteries also have a shelf life of 2 - 3 years, which means that you should always buy freshly manufactured batteries, not something that has been sitting on a shelf for a few years ."
Al di là del fatto che comunque i moderni caricabatterie hanno la funzione "STORING", per chiarezza vorrei sapere:
- In storage qual'è il voltaggio esatto che ciascuna cella deve avere?
- Anche se conservate in storage, le celle subiscono comunque un naturale degrado, dovendo fare una stima del tempo di conservazione, quanto possono andare avanti se tenute ferme? Mi pare di capire che in ogni caso, dopo 2\3 anni vanno sostituite.....
Togliamoci tutti questi dubbi....Francamente vorrei saperne di più da chi è in grado di fornire, a scanzo di equivoci, informazioni CORRETTE al 100%.
