Originalmente inviato da inquisitore Rivoltella... secondo te cosa intende con questi valori in fondo il programmino che calcola gli RPM? Quelli in rosso
Cioè non riesco a interpretare il significato della percentuale relativa al governor.... 65%, 70%, ...
PS: semmai chiedi al Brizzi ------
Voltage for this calculation (min):3,6075/cell with a total of 21,6450
Nominal voltage: Spoolup RPM 100% throttle no governor (22,2v): 2878
Avg RPM you will see with 100% throttle and no governor: 2700
Max normal bogging applied you will see RPM at: 2385
(this number should be the minimum if your motor & battery is up for the challenge) Spoolup with Governor @ 65%: 2426
Spoolup with Governor @ 70%: 2497
Spoolup with Governor @ 75%: 2569
Spoolup with Governor @ 80%: 2640
Spoolup with Governor @ 85%: 2711
Spoolup with Governor @ 90%: 2783 |
che tipo di governor hai impostato?
