Altra foto
The Pro-Peak Sigma EQ is a high performance unit for charging, discharging and cycling batteries at home or the field. Its integral Lithium Cell balancing System makes it as versatile as it is practical. Suitable for 240v AC or 12v DC input, it comes complete with adaptor boards for cycling all major brands of Li-Po batteries. Its large backlit LCD makes monitoring of the Sigma EQ's charge or discharge progress clear and simple and during balancing, each cell's voltage is displayed.
11-15v DC or 100-240v AC Input
Battery Type: Li-lon/Po - 1-6 cells (3,7-7,4-11.1-14,8-18,5-22,2 volt)
LiFePO4 - 1-6 cells
NiCd/MH - 1-14 cells
Lead-Acid - 1-6 cells
Max charge: 6A (2C Li-Po)
Max Discharge 1A
Max 50W output
Please note that due to the 50 Watt output (as found on many of the mid range chargers) as the voltage of the battery requiring charging increases the current ability (Amps) of the charger decreases. As an example a 6s 22.2v LiPo could be charged at a maximum rate of 2.25 Amps. Please consider this factor when selecting a charger to ensure that it is fully capable of charging your batteries at the expected charge rate.
Se vuoi sapere altro chiedi pure
baracca1 - MCX2 - PROTOS 700 MAX V2 - Logo550 VBar Carbon - DEVIL 380 - ESACOTTERO CRIUS AIO V2 - EACHINE E010 + H8 - SPEKTRUM DX8 - Ferrovia MARKLIN H0
