Originalmente inviato da antonov Lo vedi che ci caschi di nuovo? Un ACTRO 24-5 da 2 kilwatt e mezzo!!! E 300 di motore!
Vorrei anche vedere che non sia un buon motore!!!!!
Per il 2820/10 non so cosa dire perché nonl'ho mai provato...ho trovato un test su RCGroups: "My earlier speculation about AXI motor making a very good sailplane motor was heartily confirmed as soon as I launched my Chip. The AXI is a very smooth and powerful sailplane motor, equaling (and possibly slightly exceeding) the performance of the FAI 035. The efficiency appears to be a little less, but I still made at least a dozen climbs to high altitude with seven SR Max 2400's, and these climbs were right on the edge of full vertical, at least initially. They flatten a little as the pack runs down. My sailplane did not exhibit any bad habits at all, only awesome climbs. The motor and controller were just barely warm on landing, showing that the higher currents were no problem, at least for the comparatively short run times used during climbs. I was very impressed with the AXI in the Chip. This would be a superior upgrade for Speed 600-size sailplanes, yielding a huge improvement in performance over "can" motor." |
Esagerato, il 24-5 al massimo tira fuori 1200W continui, il 32/4 arriva a 2 KW.
Solo che essendo montati su modelli tipo pluri il motore deve sempre funzionare....
Per impieghi più pesanti ho anche questo
Peso 600 gr, potenza massima 2300W con 10 celle e 70A
montato su un Pilatus Porter della Jamara da 2400, mai finito, ma provato il motore e l' elica (una bipala 18x12 oppure una quadripala 15x10)...
Regolatore Jeti 77 OPTO, con un 12 celle si otterrebbero anche 2800W
