dai una letta quà:
Binding Connection Explained
e leggi questo:
i've got a major problem with my brand new dx7.. when i first got it i did the binding procedure and everything worked perfectly for 2 days. i flew my trex around without any problems, everything worked perfectly.. then on the third day i took it out to the field and turned on the radio, but it wouldnt do anything - i gave stick inputs but no reaction from servos. the LED on the main receiver is solid, but the LED on the small rx just keeps flashing. i tried rebinding a million times, no luck. when i rebind, the main receiver's LED goes solid but again, the small rx's LED just keeps flashing. when i did this the first time it worked fine without any problems. i have tried everything loads of times, but no luck.. any ideas??
UPDATE: ive been playing around with it more and wanted to see what would happen if i unplug the secondary rx altogether. so i unplugged it and then did the binding with only the main receiver. LED goes solid as expected. now it gets wierd again. i turn on the radio, then turn on power to the rx (again, this is without the small rx). about 2 out of ten times it connects and the servos react to stick inputs. other 8 times they do nothing and do not respond. i guess i could just sit there plugging it in and out until it works. but can i even fly without the 2nd rx?? im only flying a trex heli so i dont need too much range..
