Vecchio 24 marzo 09, 18:38   #996 (permalink)  Top
enzocom123
Sospeso
Data registr.: 21-02-2008
Residenza: S.P.Q.L.
Immagini: 14
Il Truggy
Item Number: 204015
The truggy with the 5.3 ccm Force Big Block and still more power.
The Street Breaker V32 in the V-line series of Carson. This means:
– high-performance 5.3 ccm Big Block motor
– 40 MHz Reflex Wheel remote control
– electrical starter is included.
The dynamic design mirrors performance and driving fun. The drive shafts made of steel assign the power of the Force motor on the four voluminous pin spike-tires. The light and torsion resistant CY-chassis, wide wishbones and durable oil-filled shock absorbers provides an excellent traction in every terrain. The sensitive remote control and the topspeed make the CARSON Street Breaker to a top performer.
Scope of delivery:
The ready to run truggy comes with the innovative CARSON 40 MHz reflex wheel remote control, pre-painted body, decal sheet and manual.
Technical Details:
  • 4WD shaft driven
  • 3 differentials toe-in & camber
  • adjustable front aluminium axle knuckles
  • reinforced steel main pinion gear
  • 3mm Aluminium chassis anodized with countersunk screws
  • 4 mm aluminium damper supports anodized f/r
  • aluminium radio plate anodized
  • aluminium main pinion gear cover anodized
  • 2 separately adjustable racing breaks
  • new front axle with changed axle geometry
  • aluminium steering plate with different adjustment possibilities
  • oil-filled shock absorbers with tuning springs (Ø 16 mm)
  • chassis stiffener on front and rear axle
  • 125 ml racing fuel reservoir with drain
  • completely ball-raced 32
  • 5.3 ccm Force Big Block Nitro motor
  • manifold with tuning resonance tube
  • sealed-off RC-box
  • pre-installed MHz FM RC-remote control reflex wheel
  • horizontally-mounted 9 kg steering servo with steel gearbox 7 Nm, acceleration servo with 5 Nm
  • pre-painted body with decal sheet
  • Measurements (L x W x H) 510 x 420 x 195 mm
  • toe-in f/r 352 mm
  • chassis clearance ca. 47 mm
  • Measurements tires (Ø x width) 140 x 80 mm
  • weight 3950 g
Ultima modifica di enzocom123 : 24 marzo 09 alle ore 18:45
enzocom123 non è collegato   Rispondi citando
