[QUOTE=pessottino;1423252]
Originalmente inviato da inquisitore
con me sono sempre stati veloci e gentili.....aspetto la risposta....ciao |
Eccola infatti:
> 1. Correct. There is no auto-rotation mode in fixed endpoints, only in
> governor mode. We have discussed making this change. No update as of yet.
Questa indicazione riguarda invece come settare il range dello stick gas:
> 2. Turn on your tx and set normal mode in the transmitter for a linear
> throttle curve (0,25,50,75,100). Bring your high side and low side
> endpoints on your throttle channel down to 25%, plug in the battery pack
> with the throttle stick at full (it won't start up), then bring your
> high endpoint back out towards (and sometimes past) 100% until you hear
> a single tone. Next, bring your throttle stick down to the bottom
> position and bring the endpoint out from 25% out towards (and possibly
> past) 100% until you hear the ESC arm. Unplug the battery pack, wait a
> few seconds, then plug back in and verify that the throttle is working
> properly.
