DLE55 e 111
Iniziata la commercializzazione dei nuovi DLE55 e 111 che sostituiscono i precedenti DL50 e 100.
DLE-55 50cc Gas Engine
This is the just released DL55 Has a .3 more HP than the DL50 and weighs 20g less.
Specs.
5.5HP @ 7500rpm
Idle @ 1350rpm
14.2 Kg Torque @ 100 meters
12.5 Kg Torque @ 1800 meters
Prop Size 22 x 8, 22 x 10, 23 x 8, 23 x 10
Spark Plug - NGK CM6
Parameters
Exhaust - 55.6cm3
diameter x stroke - 45mm x 35mm
Compression - 7.6:1
Oil Mix - 30:1
Weights
Engine 1310g
Muffler 100g
Ignition 120g
