Vecchio 11 marzo 09, 22:15   #4 (permalink)  Top
giovannignudi
Data registr.: 11-03-2009
Residenza: Bologna
Il modello della SAPAC ha queste caratteristiche:
Type..............................: ARF
Material..........................: Fiberglass with Foam-core/Balsa Wing
Fan size..........................: 70mm
Wing Span.....................: 950mm (37.40'')
Wing area......................: 18sq.dm (279.77 sq in)
Wing Loading.................:36g sq.dm (22.7-23.9 oz/sq ft)
Weight...........................: 1250 - 1320 grams (44.1 - 46.5 oz)
Length...........................: 1000mm (39.37'')
Included........................: 70mm EDF Fan
Radio.............................: RX with 4-5 channels, 4-6 micro servos, 1 ESC
Se copisco bene, il modello dell'E-flite essendo più piccolo diventa critico e molto reattivo presentando delle misure più contenute:
Wingspan: 33.3 in (845mm)
Overall Length: 35.4 in (900mm)
Wing Area: 206 sq in (13.2 sq dm)
Flying Weight: 43–46 oz (1219–1304 g)
Motor Size: 15 DF Brushless Motor
Radio: 4+ channels
Servos: Sub Micro (3 required, 4 with nose gear steering)
Speed Control : 60 amp brushless
Recommended Battery: 3S 11.1V 3000-3300mAh Li-Po
Landing Gear: Optional use, included
Quindi quale prenderesti ?
giovannignudi non è collegato   Rispondi citando
