Vecchio 28 febbraio 09, 12:43   #70 (permalink)  Top
Lele71
Data registr.: 04-02-2009
Residenza: Mestre
Cerca e ricerca ho trovato anche questo sistema:
MOLDIND DEPRON
Yes, DEPRON can be molded into shape using an electric kitchen oven.
* a mould out of wood, of the shape, is first made
* pre-heat your wooden mould of the shape in an electric oven for 20-30 min at 80-90 deg.C (176-194deg.F)
* form the piece of Depron onto the heated mould by first carefully cold-crushing it without cracking it.
* wrap packing tape tightly around the whole outside and seal the edges. This prevents the gases to expand and forces the depron foam to follow the shape of the mould.
* place it in the oven for 15 minutes at 80-90 deg.C (176-194deg.F)
* remove from oven and let cool for 1 hour. The depron will fix to the shape of the mould and retain its strength too.
* Carefully remove the tape. Sometimes the thin skin is compromised, but the shape is achieved.
che si trova a questo link:
Design with Foam
Lele71 non รจ collegato   Rispondi citando
