Discussione: Novità Multiplex 2009
Vecchio 04 febbraio 09, 20:13   #92 (permalink)  Top
Bad Attitude
L'avatar di Bad Attitude
Data registr.: 25-05-2005
Residenza: Montegrosso d'Asti
Merlin # 21 4237
The little magician
The name “Merlin” can apply equally well to the famed magician or the small falcon, and both descriptions are valid for our little racer.
Finally we can offer a mini-format model with a full-size performance. It's an all-in solution with many clever detail features, but above all its compact design means that it can accompany you wherever you go.
Our Merlin is agile and nimble, while its small size makes it terrific fun to fly even at small slopes. With its low weight and robust
ELAPOR® construction the risk of airframe damage is low, but despite this the model can cope remarkably well in windy conditions - this is where the “falcon” aspect of its nature comes into its own.
When flying aerobatics “Merlin the Magician” comes to the fore: the powered version in particular is capable of the wildest aerobatic manoeuvres you can imagine.
When the model is complete, it can be transported conveniently in the retail packaging. The aeroplane features a practical hatch in the underside through which the battery can be changed quickly and conveniently.
The plus points:
Simple and quick to assemble - in the air very quickly
The model can be completely dismantled for transport
Packed size only 11 x 18 x 61 cm
Optional transport bag with strap attachment (# 76 3316)
Can be built as a glider or in an electric version (with power set # 33 2653)
Docile flying characteristics
Raised ailerons as landing aid
High-quality plastic components
Major parts moulded in ultra-durable ELAPOR ® foam
Carefully matched power system gives great agility; optional increased performance by changing propellers
(both sizes included in the power set))
Li-BATT BX 3/1-450 mAh flight battery
Specification
Wingspan 783 mm
Overall length 598 mm
All-up weight glider / electric approx. 240 / 290 g
Total surface area 11.3 dm_
Wing loading 21,2 / 25.7 g/dm_
RC functions Elevator, rudder, ailerons (2 servos), throttle, Landing aid: raised ailerons
Novità Multiplex 2009-merlin.jpg   Novità Multiplex 2009-merlin1.jpg   Novità Multiplex 2009-merlin3.jpg   Novità Multiplex 2009-merlin4.jpg   Novità Multiplex 2009-merlin5.jpg
Bad Attitude non è collegato   Rispondi citando
