Vecchio 25 gennaio 09, 13:31   #286 (permalink)  Top
ITALion
L'avatar di ITALion
Data registr.: 10-08-2008
Originalmente inviato da METEOR Visualizza messaggio
salve questa l'ho letta su "heliguy.com" che dite?
Spray some WD40 in your motor now and again I should really take the motor off to do this, but haven't ever bothered so far. Just be careful not to get too much on other parts, particularly the 4 in 1, and let it all dry off before plugging a battery in. Aim carefully in the hole with the motor/heli upturned, spray, then rotate the blades in their direction of rotation a few times by hand, then dry everything with paper towel. I've found doing this every 5 - 10 flights or whenever I remember increases motor life, and livens them back up when they start to feel tired. I also never fly a full battery, and often blow in the motor during a flight to cool it down a little. This is easiest to do if you land first. ........
These helis fly better if the boom is rigid.
la modifica che ho fatto io alla coda:
http://www.baronerosso.it/forum/atta...e-dsc02656.jpg
Si il WD40 ce l'ho ed e' buono. In USA ho letto che usano il TRIFLOW che dovrebbe essere anche meglio.
- Spektrum DX7 Bearnig + Voltage MOD
- Walkera 4G6 HP08-2 (2801Pro Switch MOD)
- T-REX 450 PRO V3 - T-REX 600N LE
ITALion non รจ collegato   Rispondi citando
