| lubrificare il motore
salve questa l'ho letta su "heliguy.com" che dite? Spray some WD40 in your motor now and again I should really take the motor off to do this, but haven't ever bothered so far. Just be careful not to get too much on other parts, particularly the 4 in 1, and let it all dry off before plugging a battery in. Aim carefully in the hole with the motor/heli upturned, spray, then rotate the blades in their direction of rotation a few times by hand, then dry everything with paper towel. I've found doing this every 5 - 10 flights or whenever I remember increases motor life, and livens them back up when they start to feel tired. I also never fly a full battery, and often blow in the motor during a flight to cool it down a little. This is easiest to do if you land first. ........
These helis fly better if the boom is rigid.
la modifica che ho fatto io alla coda: http://www.baronerosso.it/forum/atta...e-dsc02656.jpg
mini heli vari |TREX 450: AGUSTA109| 450 PRO|TREX 500: MD500 + AS350 + 2 DFC SPEED  |T-REX 600E AGUSTA 109|T-REX 600 DFC!MINITITAN MD500| VARIO JET RANGER DJI WKH  |GOBLIN 700 KSE BD3SX| E-FLITE VTOL!DJI F550-NAZA|SKY STRIDER| T14SG |
