YouTube - Rich and his HET Mig 29: Second Flight
questo il modellino
YouTube - Mig 29 OVT Thrust vectoring (closeup and display) at RIAT'06
questo il modellone
per chi conosce l'inglese nn mi e chiaro un passaggio nel manuale
se ho capito bene il quota va impostato a 2gradi a cabrare?
Set the Wing incidence, set the main wings level, the elevons must be set to 2 degrees up.
This means that the trailing edge from the elevon should be set 6 mm higher than its leading
edge. You can do this by placing the main wings level on two horizontal blocks. And
measure the height of the leading- and trailing-edge from the elevon with a ruler.
First Flight.
