Importante guida in italiano per settare tutti i Regolatori Align
METTI STIK MAX
ALIMENTA REGOLATORE
SENTI UNA SERIE DI BIP
METTI IL GAS AL MINIMO
1 SETUP USANDO LO STIK DEL GAS
1/2/3/4/5/ BIP RIPETE TRE VOLTE DEVI SELEZIONARE MEBTRE LI FA
1 SETUP
1 BIP RIPETE TRE VOLTE
FRENO
BRAKE DISATTIVATO LASCIA STIK AL MINIMO
BRAKE MEDIO PORTA STIK META CORSA
BREAKE HARD PORTA STIK AL MAX
QUANDO FINISCE LA SEQUENZA DEI 1 BIP UNA SERIE DI BIP CONFERMA LA SCELTA PORTA STIK AL MINIMO
2 SETUP
2 BIP RIPETE TRE VOLTE
TIPO DI MOTORE
2 POLE STIK AL MINIMO
6 POLE STIK PORTA STIK META CORSA
OLTRE POLE PORTA STIK AL MAX
QUANDO FINISCE LA SEQUENZA DEI 2 BIP UNA SERIE DI BIP CONFERMA LA SCELTA PORTA STIK AL MINIMO
3 SETUP
3 BIP RIPETE 3 VOLTE
PROTEZIONE LIPO
2,9 V STIK MINIMO
2,6 V STIK META CORSA
2,3 V STIK MAX
QUANDO FINISCE LA SEQUENZA DEI 3 BIP UNA SERIE DI BIP CONFERMA LA SCELTA PORTA STIK AL MINIMO
4 SETUP
4 BIP RIPETE 3 VOLTE
AEREO / HELI/ HELI
AEREO STIK AL MINIMO
HELI SOFT STIK A META CORSA
HELI GOVERNATORE STIK AL MAX
5 SETUP
5 BIP RIPETE 3 VOLTE
VOLUME SUONO
STANDAR STIK MINIMO
MEDIO STIK META CORSA
ALTO STIK AL MAX
ORA TOGLI ALIMANTAZIONE
RIDAI ALIMANTAZIONE CON IL GAS AL MINIMO
SENTIRAI I 5 SETUP CHE HAI SCELTO
SENTIRAI LA SECUENZA DI BIP 1/2/3 RELATIVI ALLA SCELTA CHE HAI DECISO DURANTE LA PROGRAMMAZIONE .. IL NUMRO DI CELLE LE SELEZIONA IN AUTOMAICO
ESEMPIO
FRENO MEDIO
6 POLE
2,9 V
AEREO
SUONO ALTO
SENTIRAI QUESTA SEQUENZA
BIP BIP ------.BIP BIP -----BIP------BIP-----BIP BIP BIP
DAI GAS E PARTE ELICA
