Originalmente inviato da fulvico Sempre girovagando per il web ho trovato dei settings aggiuntivi per dx6i e blade400 : beginers level
d/r - expo
pos 0 100% expo as req" (with expo + values numb the controls - values sharpen them)+20% is a good start point for beginers
pos 1 80% expo as req"
travel adjust 100% on all exept rudder=90%
all sub trims 0 (perfect mechanical setup! )
gyro sw=gyro
pos 0 73%
pos 1 64%
normal
throttle curve .................. or alternate curve
pos L 0%......................... pos l 0%
pos 2 23% .................. pos 2 60%
pos 3 43%.................. pos 3 85%
pos 4 67%.................. pos 4 85%
pos h 100% .................. pos 5 85%
stunt pos L 85%
pos 2 85%
pos 3 85%
pos 4 85%
pos H 85% you can up these all if you want higher head speed but 85% gives a nice speed for ff figure 8s etc ( will need higher for stall turns loops etc)
hold 0.5%
pitch curve
norm pos L 35%
pos 2 43%
pos 3 50%
pos 4 75%
pos H 100% this will give lift off about mid way between half/3 quarter stick)
stunt posL 0%
pos2 25%
pos3 50%
pos4 75%
posH100%
hold 0%25%50%75%100%
swash mix airl -75%
elv -75%
pitch +85%
channel reverse ...(swash mix and channel reverse will need tweeks for those that have replaced servo's)
thro N
airl R
elv N
rudd R
gyro N
pitch N
swash set to ccpm 120 degree's ( if your going to use these settings for phoenix flight sim also.. start a new model memory copy the settings over and set the swash type to normal 90 degree's 1 servo)
throttle cut inh
dr/combi inh
timer set as req .. switch=throttle cut
power A-EU 328
for more advanced pilots the stunt throttle curve can be altered to 100% or made into a "v" curve to your own preference
Questi dovrebbero esser settaggi per principianti, siccome non ho ancora potuto metter in volo il mio, cosa ne pensate? |
che come tutti i settaggi della CASA MADRE sono solo di riferimento, sei tu in base a cio' che vuoi a come lo usi dove lo usi CHE DEVI PERSONALIZZARE QUESTE IMPOSTAZIONI
comunque su diversi siti trovi impostazioni DA CATTIVO e da VOLATO
occhio al manico........se esageri non lo tieni piu'
