Discussione: S J M * Fan Club *
Vecchio 12 dicembre 08, 23:14   #60 (permalink)  Top
fabionet31
L'avatar di fabionet31
Data registr.: 15-01-2005
Residenza: SONDRIO
Ragazzi per il mio SJM400 V3n ho preso questi servi, appena arrivano li provo e vi dico come sono:
Set of 3 Digital Servo with Ball Bearing of 12.5g grade. Specially designed for 3D electric helicopter. Faster, Stronger, and More accurate.
  • <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list 36.0pt">hHigher resolution <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list 36.0pt">hThe tightest dead band <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list 36.0pt">hAccurate positioning <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list 36.0pt">hFaster control response <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list 36.0pt">hQuicker acceleration <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; COLOR: black; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo1; tab-stops: list 36.0pt">hConstant torque throughout the servos travel
  • hIncreased holding power when stationary
DS-929MG
Operating voltage range
4.8V~6.0V
Operating temperature range
-20 to +60
Operating speed
0.12sec/60°
Stall torque
2.5kg.cm
Standing torque
1.6kg.cm hold out @ 5°
Running current
200mA/60° no load
FDead band width
≤3mS
Operating travel
40°/one side pulse traveling 400S
Motor type
cored metal brush
Potentiometer type
2 slider/direct drive
Dimensions
22.5x11.5x24.6mm(0.89x0.45x0.97)"
Weight
12.5g
Ball bearing
MR85
Gear material
metal
Connector wire length
215mm(8.46in)
Connector wire stand counter
24
Connector wire gauge
28AWG
Ultima modifica di fabionet31 : 14 ottobre 09 alle ore 22:47
fabionet31 non è collegato   Rispondi citando
