acquisto biplano
sto valutando la possibilità di acquistare questo biplano: BULLDOG 1.20 pronto al volo-phonex(safalero art PH031)
Per un eventuale motorizzazione a scoppio cosa consigliereste?
e per farlo elettrico quale motore è più indicato?grazie
Model: HXT63-74(color oro)
Input Voltage : 10~36V (3~8S Li-po)
Kv : 200 rpm/V within 10%
Dimentions : 63mm X 74mm
Shaft diameter : 10mm
Weight : 790g
Recommended model weight : 6,000~10,000g
Stator Dimentions: 52x40mm
Equivalent: 120-200 Glow Engine
Model: C63-64-B(color blu)
Input Voltage : max. 37V (10S Li-po)
Kv : 230 rpm/V within 10%
Internal Resistance : 28 mohm
No Load current @ 7V: 2.16A
Dimensions : 63mm X 64mm / 2.48in X 2.52in
Shaft diameter : 10mm / 0.39in
Weight with cables : 640g / 22.58oz
Number of poles/magnets : 14
Recommended model weight : 6000~10000g / 176~352oz
Power equivalent : .90 - 150 Glow engine
Prop: 14x10~18x12 (lipo from 6 to 8 cells)
ESC Required: 60A Minimum
Watts: 1900W
Use this motor with 3-8 cell Li-Poly packs and 19-20 inch props on planes up to 20 lbs flying weight.
Similar to AXI Gold 5330/18, AXi Gold 5330/24, E-Flite Power 160. Roughly equivalent to 1.2-1.5 2-stroke or 2.1-2.5 4-stroke glow engines.
Ultima modifica di marcus6911 : 22 ottobre 10 alle ore 15:35 |
