RAGAZZI ...
ecco caratteristiche ...mi butto ? Vi sembra ok per circa 180 euro ?
The latest ESky Belt-CP V2 is an upgrade version of the world famous ESky Belt-CP RC helicopter. With totally fresh apperance and new designs for the main rotor and tail rotor systems, the Belt-CP V2 increases the stability, powerful and accuracy of the helicopter as well as to give more direct control by the pilot.
Include EVERYTHING TO FLY!
Products Description:
Completely assembled and tested at the factory, ready to fly out box!
120 degree ECCPM Control System
High performance Heading Lock gyro is Capable of sport flying and 3D aerobatics
Stainless steel flybar, main shaft and tail shaft
450 brushless motor, 25A brushless ESC and 3S 11.1V 1800mAh 20C Li-Po battery deliver incredible power and performance.
Hold Rotation System
Tail Belt Drive System
High Inertial Main Blade
High Efficiency Tail Blade
Rear Tail Servo Stand
High Rigidity Iron Main Shaft
High Rigidity Aluminum Tail Boom
Super Iron Landing Skids
High Strength Carbon Fiber Tail Boom Support Set
Specification:
Main blade diameter: 680mm
Tail blade diameter: 130mm
Length: 640mm
Height: 230mm
Weight: about 670g (including EK1-0186 Li-Po)
Motor gear: 10 teeth
Main driven gear: 140 teeth
Tail driven gear: 110 teeth
Driven gear ratio: 14:1:5
Package included :
1 x ESky Belt-CP V2 Helicopter Body, All Electronics Installed, Ready-to-Fly
1 x 3800KV brushless motor (EK5-0006)
1 x 25A brushless speed controller (EK1-0350)
1 x ESky professional headlock gyro (EK2-0704
![B)](/forum/images/smilies/cool.gif)
NEW!
4 x 7.5g Digital Servo (EK2-0508) NEW!
1 x ESky 6-channels PPM / CCPM Transmitter (EK2-0406F) NEW!
1 x ESky 6-channels CCPM Receiver (EK2-0420A)
1 x ESky 1800mAh 20C Li-Po Battery (EK1-0186)
1 x 7.4V & 11.2V Li-Polymer Battery Charger (EK2-0851)
1 x 100-240V AC Switching Adapter (EU, US/JP, UK, AU) We will choose the correct one for your country!
1 x Colourful English & Chinese Manual (incl. spare parts list) for RC Helicopter
Ricordo a tutti quelli che mi vorranno consigliare in questa scelta finale
che ricerco precisione di volo,hoverig senza slogarsi i pollici...,non mi interessano i tagliaerba... e sopratutto una felice progettazione e una buona ed economica riparabilità..
Vado ?????? Aiutatemi e poi non rompo più !!
Grazie a tutti.
