Vecchio 22 settembre 08, 10:44   #13 (permalink)  Top
HYCRYPOTES
L'avatar di HYCRYPOTES
Data registr.: 15-07-2008
Originalmente inviato da HYCRYPOTES Visualizza messaggio
Che tipo di impostazioni ha?
non lo conosco, però dai dati e le impostazioni dichiarate preferirei prendere questosta anche 100 euro in meno
TMM 25035-3 Car / Boat Z-SERIES | for Cars / Boats | Brushless Speed Controllers | MGM Compro - Electronics for Models
Technical data Show DetailsHide Details
Controller for motors brushless
Reversible controller
Number of Li-Ion, Li-Pol feeding cells 3 - 8
Number of NiCd, NiMh feeding cells 9 - 24
Number of A123 feeding cells 4 - 9
Compatible with any feeding cells
Operating voltage 9 - 35.0 V
Max. continuous current (for full throttle) 250 A
Max. peak current (peak 5 sec.) 300 A
Version BEC / Switching BEC / OPTO OPTO
BEC voltage - V
Max. BEC current at 25 °C - A
BEC short circuit protection
Number of regulation steps 1024
PWM frequency 8/16/32 kHz
On-state switch (FETs) resistance at 25 °C 2 × 0.28 m
Dimensions 50×31×22 mm 1.97×1.22×0.87 in
Dimensions with external capacitor 80×31×22 mm 3.15×1.22×0.87 in
Weight without power conductors 81 g 2.604 oz
Weight incl. all conductors 119 g 3.826 oz
Power conductors cross-section to batt. / to mot. 6/4 mm2 0.0093 in2
Length of the power conductors 110 mm 4.331 in
Servocable cross-section 0.25 mm2 0.0004 in2
Length of the servocable 190 mm 7.480 in
Design possibilities:
Possibility of design with external heatsinks
Possibility of design with water-cooled heatsinks
Possibility of design with external heatsinks + FAN
Possibility of "hydro" version
Possibility of design with switch (connected safely)
Programming and PC Cooperation Features:
Software updates available through internet
Programming using PC
Universal programming card
Programming using throttle stick
Reading-out of data from the controller using PC
Cooperates with Black Box (data logger)
ICS connector - communication with PC without manipulation with servocable
Features:
Plug and Play (functional immediately without the need for additional programming)
Higher resistance against overloading
Outstanding cells management
Extremely powerful Switched BEC
Extremely powerful MEGA BEC
Possibility of setting the voltage of BEC
Possibility of setting an amount of residual energy for BEC
Possibility of setting switching off voltage
Possibility of automatic setting of cut off voltage
Possibility of manually set number of cells
Manually set type of cells
Automatically set timing
Possibility of manually set timing
Possibility of automatic setting of throttle limits
Possibility of switching reversible controller into "one-way" mode
Active free-wheeling circuit ON / OFF
Brake ON / OFF
Proportional brake
ABS simulation
Brake strength
Possibility of automatic braking in neutral throttle position
Setting of the range of neutral zone
Possibility of connecting braking lights
MGM Race Mode 2
Acceleration
Deceleration
When batt. low (almost empty) - motor power reduction
When batt. low (almost empty) - instant motor cut-off
Software reversal of rotation
Masking of interference
False-start protection
Current fuse of the controller
Temperature fuse of the controller
ACR - Automatic Current Reduce
ACL - Automatic Current Limiting
Ultima modifica di HYCRYPOTES : 22 settembre 08 alle ore 10:47
HYCRYPOTES non è collegato   Rispondi citando
