Originalmente inviato da fai4602 Se non è cambiato qualche cosa che non sò, il Solartex è bianco e non trasparente e ciò che appare della struttura appare come con tutti i rivestimenti non trasparenti. |
Qualcosa evidentemente è cambiato .... sono presenti alcune nuove tinte "semitrasparenti".
Dal sito del produttore:
IRON-ON COVERING FABRIC FOR MODEL AIRCRAFT
Iron-on self adhesive fabric. Very strong and tough covering material, stronger than films but heavier. SOLARTEX has the textured surface of a fabric. The fabric surface has been protected by a tough coat of two-pack resin to make it airtight and fuelproof. The back of the fabric is coated with a colourless heat-seal adhesive. On the model the Solartex is easily cleaned with soapy water when soiled.
Apply CLEARCOAT to convert to a glossy surface and protect against soiling.
Vintage colours are 'see-thro" like coloured silk. Dark Green is PC 10 as used on WWI aircraft.
Antique is a 'see-thro' cream. Linen is an opaque cream. Silver is exactly like a silver doped fabric.
Weight 85 to 95 g.s.m.
Roll sizes 2m. & 10m. by 0.68m. wide.
