regolatore mystery su t-rex 500 che ne dite??
raga' ho preso un regolatore mystery 100ampere
Size: 74.4mm x 39.1mm x 15.9mm
Constant Current: 100A
Max Current: 110A/12s
Input Volt: 6 - 22.2V
Low-Voltage Cutoff: Auto detect and set
Advantage of the Mystery Speed Controller
Low resistence
High rate PWM
User programmable brake
Low voltage auto setting based on battery
Throttle range self-adjusting
Soft start ramp up
Runs motor in forward or reverse
Auto motor cutoff with reset
Safe power arming program ensures motor will not run accidentally after turn on
Low torque start
Auto shut down when signal is lost
andra' bene per il mio t-rex 500???vorrei cambiare il mio align ....che ne dite???
