Originalmente inviato da jari81 dipende quanto vuoi spendere... io uso un ultrapeak 3.0 comprato da jonathan.it |
Vedo che hanno disponibile la versione 4.0 sempre nello stesso shop.
Non è poco 4A di carica massima ?
Grazie mille
Che ne dici di questo ?
Features
- High speed sample rate negative delta voltage and zero delta voltage auto-detect cut off circuit with MOSFET control for peak detection. Pulsation charge method to prevent overcharge and overheat.
- Charge Ni-MH battery by Zero delta voltage technology without using thermo-detection probe.
- Auto-detect switching charge mode for Ni-CD and Ni-MH battery.
- Front panel with "MODE" buttons and dial log to select charging current.
- "DIAL LOG" to select charging current from 0.5A~4.0A, 0.1A step up.
- 3LED indicator for SLOW CHARGE, FAST CHARGE and POWER.
- Low power amplifier and low offset voltage comparator.
- Volt threshold 4mV/cell for Ni-CD and Ni-MH battery.
- Auto-detect battery pack number of cells.
- Trickle current (0.1A) fter fast charge mode finished.
- Reverse polarity protection system.
- Charge batterypack with combination 4~8 cells.
- Build in auto switching power supply with input 100~240V AC.
- 4cm cooling fan to enhance the performance.
Specification
Qty: 1Pc
Colour: Black
Input Voltage: AC 100V~240V
Number of Cells: 4~8 cells
Battery Voltage Range: 4.8V to 9.6V
Charging Current: 0.5A to 4.0A
Lo prenderei dal negozio assieme alla macchina...
