se è quello di hc, i dati sono questi, 160g mi sembrano troppi.... Micro 4.6g outrunner motor details.
Ultra thin stator laminations and silver wire turned very tightly making this a well performing micro motor!
Weight: 4.6g
Size: 14 x 12mm
Shaft: 1.5mm
Kv: 3700rpm/v
Prop: 2510 or 3020 Setups; Prop: 2510
Max Voltage: 8
Max Amp: 2.8A
Thrust: 90g Prop: 3020
Max Voltage: 8.4
Max Amp: 1A
Thrust: 49g
