04 febbraio 09, 20:05 | #91 (permalink) Top |
User Data registr.: 25-05-2005 Residenza: Montegrosso d'Asti
| Xeno The flying wing for ultimate slope and electric flying fun # 21 4239 At many slopes and flat-field flying sites you will find dozens of flying wings. These models are usually cut from various grades of foam and stiffened with parcel tape. The Xeno is a superior version: more elegant, of higher technical quality, and offering loads of convenience as well as excellent flying fun. When designing the Xeno we made good creative use of the possibilities of 3-D CAD / CAM techniques and modern foam moulding technology. The result is an interesting shape with an unmistakable appearance. For ease of transport the Xeno can simply be folded together in a few seconds, and in this state it can be carried safely and conveniently in a rucksack or similar. Rigging the model for launch also takes just a few seconds, and converting it to electric power and back is almost equally rapid. With its simple construction and high level of pre-fabrication it only takes two or three hours to assemble the Xeno (i.e. one evening - it really doesn't count as construction!) The plus points: Requires just a simple radio control system with delta mixer Numerous high-quality injection-moulded plastic parts provide interesting detail solutions Strong and rigid without the need for taping - thanks to ELAPOR ® construction Removable / replaceable fins The finished model can be folded together, making it very easy to transport Good-natured flying characteristics, simple to fly (great for beginners), stall-proof Broad speed range - a genuine fun-flyer! Optional electric power set: fitted in seconds. Optional transport bag with strap attachment (# 76 3317) Specification: Wingspan: 1245 mm All-up weight, glider / electric approx.: 395 g / 460 g Total surface area: 32 dm_ Wing loading: 12.5 to 14.5 g/dm_ RC functions: Elevator, aileron (delta mixer), optional throttle |
04 febbraio 09, 20:13 | #92 (permalink) Top |
| Merlin # 21 4237 The little magician The name Merlin can apply equally well to the famed magician or the small falcon, and both descriptions are valid for our little racer. Finally we can offer a mini-format model with a full-size performance. It's an all-in solution with many clever detail features, but above all its compact design means that it can accompany you wherever you go. Our Merlin is agile and nimble, while its small size makes it terrific fun to fly even at small slopes. With its low weight and robust ELAPOR® construction the risk of airframe damage is low, but despite this the model can cope remarkably well in windy conditions - this is where the falcon aspect of its nature comes into its own. When flying aerobatics Merlin the Magician comes to the fore: the powered version in particular is capable of the wildest aerobatic manoeuvres you can imagine. When the model is complete, it can be transported conveniently in the retail packaging. The aeroplane features a practical hatch in the underside through which the battery can be changed quickly and conveniently. The plus points: Simple and quick to assemble - in the air very quickly The model can be completely dismantled for transport Packed size only 11 x 18 x 61 cm Optional transport bag with strap attachment (# 76 3316) Can be built as a glider or in an electric version (with power set # 33 2653) Docile flying characteristics Raised ailerons as landing aid High-quality plastic components Major parts moulded in ultra-durable ELAPOR ® foam Carefully matched power system gives great agility; optional increased performance by changing propellers (both sizes included in the power set)) Li-BATT BX 3/1-450 mAh flight battery Specification Wingspan 783 mm Overall length 598 mm All-up weight glider / electric approx. 240 / 290 g Total surface area 11.3 dm_ Wing loading 21,2 / 25.7 g/dm_ RC functions Elevator, rudder, ailerons (2 servos), throttle, Landing aid: raised ailerons |
04 febbraio 09, 20:21 | #93 (permalink) Top |
User Data registr.: 19-01-2007 Residenza: Dintorni di mestre (DINTORNI)
Ok... Praticamente un elicottero con motore in diretta (ecco una cosa interessante... il motore in diretta su un elicottero) Un tuttala da pendio... Un EasyGlider versione mignon... Carino il tuttala (almeno lo è la parte ricevente... non il solito buco chiuso con scotch) |
04 febbraio 09, 21:04 | #95 (permalink) Top |
User Data registr.: 21-10-2008 Residenza: Torino
davvero molto belline!dell'elicottero non m'interessa un granche....ma del tuttala e del maxi fox invece inizio già a farci un pensierino.....vedremo
__________________ Ogni cosa che sentiamo è un'opinione, non un fatto. Ogni cosa che vediamo è una prospettiva, non la realtà. |
04 febbraio 09, 22:27 | #98 (permalink) Top |
Coordinatore dello staff Data registr.: 16-02-2004 Residenza: Roma Snakes Hill
La vera novità di rilievo mi pare sia questa: http://www.mpx.speedkom.net/cms/vors...iges/2_4_I.pdf
__________________ Sandrone: un uomo di un certo peso. |
Easg 2009 | TORVO | Categoria Rc-Combat | 23 | 01 aprile 09 00:42 |
novità calendario 2009...... | artu | Aeromodellismo Categorie | 6 | 04 gennaio 09 11:11 |
norimberga 2009 | igino | Incontri Modellistici | 4 | 21 ottobre 08 16:50 |
Novità Multiplex 2008 | gogiamma | Aeromodellismo | 73 | 08 febbraio 08 16:19 |
Ac- 2009 | claudioD | Navimodellismo a Vela | 8 | 01 gennaio 08 12:47 |
