Discussione: Modelli e limiti
Vecchio 23 novembre 10, 05:20   #414 (permalink)  Top
John Doe
Sospeso
Data registr.: 13-09-2010
Residenza: Vicenza
Immagini: 3
Originalmente inviato da giobalde Visualizza messaggio
Per me' ok con la sola nota, come gia' scritto, del peso intermedio che abbasserei.Ciao giobalde
Negli Stati Uniti il limite intermedio è 25 kg (55 pounds):
2011 Official AMA National Model Aircraft Safety Code
A. GENERAL: A model aircraft is a non-human-carrying aircraft capable of sustained flight in the atmosphere. It may not exceed limitations of this code and is intended exclusively for sport, recreation and/or competition. All model flights must be conducted in accordance with this safety code and any additional rules specific to the flying site.
1. Model aircraft will not be flown:
(a) In a careless or reckless manner.
(b) At a location where model aircraft activities are prohibited.
2. Model aircraft pilots will:
(e) Not exceed a takeoff weight, including fuel, of 55 pounds unless in compliance with the AMA Large Model Aircraft program. (AMA Document 520-A)
AMA Large Model Aircraft Program Requirements and Inspector Information
1. General. All pertinent FCC regulations and AMA regulations shall be applicable.
Individuals interested in qualifying an RC aircraft to be flown in this category must obtain an application form, and handbook/guidelines. Any aircraft must be certified airworthy through the issuance of a Permit to Fly from a current AMA Inspector, PRIOR to any demonstration, practice, or general flying.
1.1 Definition: A Large Model Aircraft (LMA) is one that is produced under the strict guidelines and regulations set forth in these conditions as stated herein. Aircraft models shall weigh no less than 55 pounds nor exceed 100 pounds [45 kg] maximum, with fuel, ready to fly.
Insomma, 20, 25 o 30 kg sono limiti ragionevoli su cui si può discutere, ma il limite di 8 kg, come stabilito nella guida FIAM, è semplicemente inaudito (per non parlare del resto... ).
John Doe non è collegato   Rispondi citando
